D15B VTEC
Found in:
1992–1995 Honda Civic Vti (Japanese Market)
1992–1998 Honda CRX DelSol (Japanese Market)
Bore and Stroke :75,0×84,5 mm
Displacement : 1,493 cc (91.1 cu in)
Rod Length : 137 mm
Rod/Stroke : 1.63
Compression : 9.3:1
Power : 130 PS (96 kW; 128 hp) at 6,800 rpm[5]
Torque: 14.1 kg·m (138 N·m) at 5,200 rpm[5]
VTEC switch over : 4,800 rpm
Redline : 7,200 rpm
Rev-limiter : 7,200 rpm
Valvetrain : SOHC VTEC (4 valves per cylinder)
Fuel Control : OBD-1
Head Code : P28
ECU Code: P08 (small case ECU)***
you will like the D15b better, but the Z6 is easier to get domestically.. or right now if you really wanted one.
