I am doing my own ground wire kit using 6 gauge wire. So far i have replaced the factory ground wires ( 1 going from the engine block to the frame and 1 going from the valve cover to the frame), a wire going from the negative battery treminal to the frame, and 1 going from the negative battery terminal to the engine block. Is this the right setup? And if so where can i put other wires?
