it doesnt pop up when u click it? sorry im new to this i suck...rickles8099 said:can you zoom in on it? i cant even see where its coming from.
can i just close it off with something? or is it important?Tom said:it's the PCV hose, depending wher ethe PCV cnister is may determine where you may have to re-route you PCV hose, or you may not have if the stock hose came up into the same area.
lol, you need itDoUgHb0y said:can i just close it off with something? or is it important?
if your turbo'd then you can go without it, but if you not then your going to need it.DoUgHb0y said:can i just close it off with something? or is it important?
thats a coolant hose, goes to the throttle body, just leve it, if all your doing is swaping the intake manifold it should just bolt on and connecto everything.DoUgHb0y said:
That which i think only came "or i heard" on the 90/91 manifolds but it could have been 88/89, idk. But anyways it's for you're fast idle solenoid i think is what it is called, i might be mixed up though. What you can do is get something to plug it up with or over, and the port on the top left can be plugged also. I have both of the manifolds, one with and one without, i rather use the one without...makes things simpler. 8)Green 91 said:where? is is wher ei circled? what year SI manifold is it from?
i think it 88-89 has some kind of valve thing there, and 90-91s have a L shaped pipe on it for the barke booster hose.
DoUgHb0y said:I put on a crx si manifold and its confusing i need help!!!!!
