ok how the hell does one put an rmf style 4-1 drag header into a 6th gen, h22a w/o pulling the engine????
reallly getting frustrating...
wont fit through the top or bottomI fail to see what you're having such an issue with?
RMF "drag" header?? Specify.
Long tube (top tubes out of the head are long), or are you talking side exit header?
Is the header a H2B RMF drag?
We need more info, not just a "WTF!" post.
at that angle the flange that bolts to the head is wider then the room between my head and front of my chasis..how does it not fit?
angle it so the collector points straight at the ground, slide it down around under the pan, and bolt it up.
You may have to pull the radiator. But pulling the motor is absurd.
On H swap civics, its easier to just pull the motor than f**k with pulling the trans lol.im thinkin atleast pullin the fans and radiator out, if that doesnt work then you might have to detatch a few mounts (side mounts/subframe) and lower the engine down a little then slip the header out, at that point if you STILL cant get it id say remove the trans maybe before the whole motor.
