are you speaking of the pre-load on the ingalls damper? because my NRG also has one. I'm curious as to see what your damper looks like on the inside, out of curiosity have you taken a look?oc_civic said:this apprears to be one of the differences.. the Ingalls one does not need anything changed the stiffness adjustment is all sefl contained and just requires a few spins of an open end wrench..
Yes, Its a teflon/poly bushing of sorts.vspec sir said:are you speaking of the pre-load on the ingalls damper? because my NRG also has one. I'm curious as to see what your damper looks like on the inside, out of curiosity have you taken a look?
Oh yes, thats one of its main features.SCCRules said:very nice! does it reduce any wheel hop at all?
yesSCCRules said:very nice! does it reduce any wheel hop at all?
i have not personally taken it apart no..vspec sir said:are you speaking of the pre-load on the ingalls damper? because my NRG also has one. I'm curious as to see what your damper looks like on the inside, out of curiosity have you taken a look?
really? I'm not trying to get into a debate (NRG vs Ingalls) or anything by all means, but I just read through a set of instructions for the stiffy, and It's exactly the same as my damper, well as far as the adjustments go, and exterior visual inspection. Perhaps there is a misinterpertation of what the bushings actually do. The length adjustment, is exactly what it does, physically adjusts the length of the damper to fit the mounting brackets properly. The Pre-load adjustment is going to effect your overall "stiffness" between your chassis, and your motor itself. The bushing inside simply acts as a sort of bump stop to kind of absorb some of the lateral shock/vibration during shifting or weight transfer, but not intended to take the blunt of the weight transfer, that is what the chassis is for. So, increasing the pre-load increases overall stiffness. By all means, I didn't mean the interchangable bushing inside of the NRG damper is what directly determines the stiffness, it's the pre-load adjustment that determines that, and it also looks like that the Ingalls damper is set up the same way. Perhaps they are the same as far as function goes, the only difference might be damper quality, and price. You get what you pay for... that's true, but like I said I've never had any problems with mine, and I've had my damper longer then you I'm sure. I remember reading somewhere, in some Acura forum that some guy did a review, and found that all of the dampers are actually the same design. Now without visual inspection of the interior this cannot be determined. I'm not trying to put down the Ingalls damper at all, or take over your informative thread, I Just don't see how it's that much different from NRG's. none the less, this is a good write up.oc_civic said:i have not personally taken it apart no..
there are two types of adjustments made.. stiffness and length.. both of them are done with a wrench on the outside..
spoon_ferio said:I wonder how the NRG Innovation's damper is :crook: That one is only $80.
prwil3030 said:I heard Ingalls is the best one out there so far. For $75 is not bad, the torque damper work good, but the bracket design really sucks. My opinion, if you are going to have it for a ek with a b16, dont buy unless you have skills to modify the bracket.
http://www.honda-tech.com/zerothread?id=1645065prwil3030 said:That's the one I bought, damper works buy the bracket desing suckssss. Up to you!!!!
^got your order, going to pick some up today, I will ship it by the end of the day and reply with a tracking number.Slammed_am said:Thanks a lot Tai.With the results both should provide, and less "shakes" it'd probably be a nice combo. Time to order mine from CorSport!
Yep, about to run up there -- do it now and I Ill get it out.sk8shorty017 said:if i order now, would you also be able to ship out by the end of the day? thanks
done.corsport said:Yep, about to run up there -- do it now and I Ill get it out.
Tai
