Ksport Kontrol Coilovers Coupon
Discussion in 'TunerSports / ClubCivic.com Store' started by Jay Jay, Oct 14, 2014.
  1. Jay Jay
    Jay Jay Administrator Staff Member Registered VIP Registered OG Premium 5+ Year Member 10+ Year Member
    Jan 1, 1970
    5,342
    Save on Ksport Coilovers with Coupon Code: SaveOnKsport
    Ksport Kontrol Pro Damper System Coilovers
    [​IMG]
    <p>
    <p>Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber can be adjusted via the Pillow-ball Top Mounts, which means no additional “Camber Kits” are needed.</p>
    <p>Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.</p>
    <p>The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires more expensive design process. Aeration and cavitation are a lot less common in a Monotube design, which results in a better ride.</p>
    <p>The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.</p>
    </p>
    <p>Spring rates are always shown in kg/mm / lbs./in <br />
    ATM = Aluminum Top Mount <br />
    P/U = Pillowball Upper Mount <br />
    OEM = You must resue your OEM top mount</p>
    <p><strong>Features:</strong></p>
    <ul>
    <li>
    <ul>
    <li>36 way adjustable damping</li>
    <li>Collars and upper mounts made from 6061 aluminum with T6 for increased hardness</li>
    <li>Adjustable spring perch for height adjustment</li>
    <li>Adjustable lower mount allowing maximum suspension travel</li>
    <li>Camber adjustment on vehicles with McPherson type suspension</li>
    <li>Pillowball top mount for increased steering feel</li>
    <li>Monotube high pressue design reduces oil leakage</li>
    <li>Electroplated body for added protection from corrosion and rust</li>
    <li>Dust boot to protect damper seal</li>
    <li>18 month limited warranty</li>
    </ul>
    </li>
    </ul>
    Shop at TunerSports<br>
    http://www.tunersports.com/ksport-kontrol-pro-damper-system-coilovers_mp72.html
    OR<br><br>
    Shop in the Store<br>
    http://www.clubcivic.com/store/ksport-kontrol-pro-damper-system-coilovers_mp72.html
Loading...
Share This Page
