43 is fuel supply system. I would look into the fuel filter then the pump if the filter change does nothing.
yes it cel light don'tcome on when i first start the car but after driving for a while... it comes on and goes off when u turn it off...cheezeonmakneez said:so if im not mistaking you only have code 1 now?
u mean checking the code? grey jumper? cuz on my car its blue too wit two wires tho not the three wired one... on this site it says its grey and all but its really blue for fifth gen that i kno of.... if u goto h- t theres couple threads, the newest one shows blue instead of grey.... (thats if u mean by checking for CEL)--<EM1>-- said:im dumbfounded as well. i reburned my chip bc of the rpm limitation, but im still getting a CEL. i dont have the grey jumper off the ecu, its blue, and the SRS light comes and flashes once instead of the CEL.
koo i'll look into that... imma try to do everything tomorro and see... my o2 sensor didn't come in yet...coops92hatch said:i had this same problem once, find a set of injectors you know work and when changing them clean out ur fuel rail thoroughly but careful not to scratch anything, check all of your fuel lines even the ones under ur car to make sure none of them are pinched. thats really all i can think of with the fuel system that normally goes wrong. u said ur goin to change ur cp, and all ur belts cus it wobbles a bit, that could also cause a knock causing a misfire, im not sure but i think u said it was a z6 and they dont have knock sensors so it could throw a fuel system code if a misfire occurs.
