I got the same car, but black and had thought of doing the jdm console, but then you lose your cup holders...guess it's worth it in the name of jdm right?
quick question...how expensive was it to get all your engine work done and get that d ready to make 300 whp? couldnt you just get a b18c and boost the hell out of the stock internals and get 300 whp? it would cost the same as all the mods for the d right... and you bought a different d16z6 right? plus aren't the b-series tranies better than the ex's d tranny?
I'm new to the honda (well the fist car I've actually felt like doing anything to) scene.
you can get 300whp ot of the D for under $4k easily, this is my parts list for my setup so far with prices. as you can see there are some items not needed to make 300+whp, such as gator axles. from what ive seen b18c's go for well over $3k for just the motor, then you have the turbo setup, headstuds atleast for the motor, all the parts necassary to swap in the b18c, tuning, it adds up quick. then theres the shock value of a fast d
-Motor:
YCP Vitara 75.5mm pistons…….$129
Eagle H-Beam Rods……$300
Rod/Main Bearings……$75
Timing Belt/Water Pump……$75
.037" head gasket……$65
Fuel Regulator……$75
ARP Headstuds……$105
Gator Axles……$430
SPEC Clutch……$325
Balanced/Polished Crank……$75
AVID Billet Motor Mounts……$253
OEM Fresh Flywheel……$60
Skunk2 Cam Gear……$40
Precision 780cc Injectors……$330
GM 3 bar amp censor……$70
Injector Resistor……$15
-Turbo Setup:
Bullseye T3/TO4E 50 trim w/ .55 a/r……$605
GO-AUTOWORKS 3” Custom Downpipe……$300
GO-AUTOWORKS Custom Dumptube……$70
GO-AUTOWORKS Tuner Charge Pipe Kit……$205
GO-AUTOWORKS 28x11x3 FMIC……$150
Tuner Toys Stealth Return Line……$83
Tial 50mm BOV……$175
Tial 38mm Wastegate……$175
Total: $4185
Also expect around $1100 more for short block assembly/bore/notch and the tuning
awesome dude. 300+ is a kickass
haha i hope so!
