2000 Civic Si
engine:
B18B1 Honed LS Block (OEM Rods/Pistons)
B16A2 Polished Si Head (OEM Valvetrain)
ARP Headstuds
ARP Rod Bolts
OEM Piston Rings
OEM Rod/Main Bearings
OEM Oil/Water Pumps
Cometic Head Gasket
OEM Upper/Lower Gasket Set
Garrett T3/T4 57 Trim Turbocharger
Garrett Core Intercooler 22"x6"x3"
Golden Eagle VTEC Line Kit
Golden Eagle Oil Return/Feed Line Kit
Vibrant 2.5" IC Piping (charge pipe powdercoated gloss black)
Vibrant Clamps, T-Bolts, Sleeves
Vibrant 3" Turbo TPV Exhaust
Custom Fabricated Ram Horn Turbo Manifold
Custom Fabricated 3" Turbo Downpipe with 3\" Flex
Tial 38mm Wastegate with 7psi Spring
Tial 44mm Blow Off Valve
RC 650cc Saturated Injectors
OBD1 Injector Clips
OBD2 to OBD1 Conversion Harness
Apexera (Apexi) PowerFC Standalone ECU (tuned from B16B basemap)
S4C B16A2 Hydro Tranny
Exedy Cerametallic Clutch
Exedy 9lb Flywheel
MSD 8.5mm Super Conductor Plug Wires
NGK BKR7E Spark Plugs
OEM GSR Powdercoated Satin Black Valve Cover (cam gear cut)
OEM JDM Oil Cap
Mishimoto Dual Core Aluminum Radiator
Mugen 68C Thermostat
Spoon Sports Resevoir Covers
BuddyClub Radiator Fan Switch
Gates Racing silicone radiator hoses
(im sure i forgot something...)
suspension:
RS*R Race Springs
Tokico Illumina Adjustable Shocks
Omni Power Front Upper Control Arms
Omni Power Rear Lower Control Arms
Skunk2 Rear Upper Strut Bar
Skunk2 Rear Lower Reinforcement Bar
OEM EM1 Front Upper Strut Bar
OEM EM1 Rear Lower Sway Bar
Brembo Cross-Drilled Front Brake Rotors
Brembo Blank Rear Brake Rotors
Akebono ProAct Ceramic Brake Pads (all 4)
Konig Helium 15\"x6.5\" Bronze with DIY Red Lip Wheels
Yokohama AVS ES100 205/50/15 Tires
exterior:
JDM SiR Folding Power-Adjusting Side Mirrors
Polyurethane Mugen Style Front Lip
DIY Black OEM Headlights (Nokya Hyper Yellow H4)
Volkswagon Borra/Jetta 1.8T Trunk Badge
Generic Aluminum Front and Rear Tow Hooks
interior:
Recaro Speed6 Black Cloth Bucket Seats
CTR Shiftboot
CTR Black Teflon Coated Shift Knob
B&M Short Throw Shifter
'99 CRV Amber Dial Gauge Cluster
CTR Carbon Fiber Gauge Bezel
Apexera PowerFC Commander
Pioneer DEHP6400 Headunit with Integrated XM Radio
Audiobahn A8000T Amplifier
Audiobahn Digital Battery Voltometer
Full Size Matching Spare Wheel/Tire
(Carpet, rear seats, interior panels, and trunk are removed)
**since the pic was taken the Intercooler and piping was painted black, the lip was changed to a polyurethane "type r", and benen #202 tow hooks were installed front and rear.
