I've got a Megan rear kit.. decent price and does the job. It has been installed for over a year and thus far no problems.Megan, Skunk2, Blox
to name a few
i dont have a rear kit, but when i went to get an alignment, they guy said he woulndt shim it because that would be dangerous. so i rock 0.0 in the front, and -3.6 in the rearMidas, Brakemax, Meineke.
why not? wearing out your tires even more. What's the cost of a Blox kit?I had my car aligned and they told me that my car camber is on the max limits (-2.0) but they said it is ok, there will no problem with that :-) and even they did not recommend the camber kit.
lol i don't think they do 4x100 GM ITR wheelsMidas, Brakemax, Meineke.
tire wear isnt a huge problem, i can barley feel the difference on these for the moment.why not? wearing out your tires even more. What's the cost of a Blox kit?
Seven dollars?tire wear isnt a huge problem, i can barley feel the difference on these for the moment.
as for the second one...please dont make me say the "S" word...
Hahahahah you saw that?lol i don't think they do 4x100 GM ITR wheels
yeah kinda wishing i was five lug right nowHahahahah you saw that?
how do you do this?i did the washer trick on the rear, with an omni power a-arm kit on the front. both are within factory spec
You will need to find longer bolts for the rear upper control arms and a hand full of washers. Place the bolts through the control arm and slip the washers behind onto the bolts. add or subtract washers to Change you camberhow do you do this?
does this work the same as a camber kit? any consequences from doing this?You will need to find longer bolts for the rear upper control arms and a hand full of washers. Place the bolts through the control arm and slip the washers behind onto the bolts. add or subtract washers to Change you camber
