SpoofMastaFly
So I've been trying to fix this problem for awhile now. I've got a 1992 Honda Civic hatch, (VX has a b18a1 swap) I've checked the fuses, replaced the bulbs, and checked the reverse sensor on the transmission. All work, nothing is blown. I've looked at the wiring at the inner tail lamps and none is cut up. (I replaced the rear lamps) The grounds also look fine.
The issue is when I have the car in reverse, I turn the ignition on and the reverse lamps turn on. As soon as I turn on the parking lights OR head lights, the reverse lights turn off. I have unscrewed the reverse sensor and held the button down still does it. I have unplugged my head lamps, still does it. I have unplugged my rear lights and it still does it.
So I'm pretty lost, and I'm about ready to just run a wire and switch to the reverse lights and use that whenever I need them.
Also forgot to mention I jumped the reverse switch wires and got the same response. Lights turn off when the running lights or headlamps are on. Ive also taken apart the light switch and cleaned and regreased all the terminals and connections.
