SpoofMastaFly
I pulled the running light fuse, and the reverse lights work fine. So its gotta be something with them.
That's expected and yields little new information. It's like turning the light switch off.I pulled the running light fuse, and the reverse lights work fine. So its gotta be something with them.
Ok i'll do that.That's expected and yields little new information. It's like turning the light switch off.
By removing the bulbs and unplugging the switch, you'll know whether or not power from the ground wires turns the reverse lights turn off.
With and without the light switch on?With all the bulbs removed, the reverse lights do not come on at all.
With the bulbs removed, do the reverse lights fail to work both with and without the light switch on?With the bulbs installed the reverse only came on if the car was on, turn on the light switch and they turn off.
Please give the details. When this happens:Ok so once I install the inner running bulb the reverse lamps come back on.
Again, please give the details. When this happens:Now whats weird is when i turn the car to run, the reverse lights come on AND the running lights come on but are very dim.
With the reverse light bulb removed, redo this resistance measurement on the black wire with all bulbs removed.What resistance to body ground do you measure on the black wire terminal of the reverse lights socket?
This^ is the accessory position - ON(I). The reverse lights should only turn on with the key in ON(II).1: ON (1)
The running lights should only turn on when the light switch is on.2: Light switch OFF (reverse comes on) and the running lights are on but very dim. Once I turn the switch on, the reverse lights turn off.
Resistance is slightly under 5 ohmWith the reverse light bulb removed, redo this resistance measurement on the black wire with all bulbs removed.
Then turn the key to ON(II), and measure voltage to body ground on the Grn/Yel power wire in the reverse light socket.
Excuse me, the reverse lamps come on in the ON (II).This^ is the accessory position - ON(I). The reverse lights should only turn on with the key in ON(II).
Were ALL bulbs removed for this test?Resistance is slightly under 5 ohm
And I am getting 12 volts at the GRN/Yel wire.
Now install just the reverse light bulb and it should turn on based on your voltage and ground measurements.Yup all bulbs were removed for that test.
