Long story short, im running nitrous on my stock gsr currently. i decided a few days ago that i wanted to ditch the zex kit and give her some boost lovin. well, i ended up buying a gt35r that night and things went a little further than originally intended (goals of 250whp on stock motor). anywho, now im goin for 400whp and decided to do a mild bottom end build to support it.
I'll keep this thread updated as i get parts and what not. im shooting to be finished in about 4 months, we'll see how that goes.
After ordering the GT35r two days ago, i went to pick up some JE 9:1 pistons today. i also was finally here at my house when the UPS man stopped by (for the 3rd try) with my stage 3 Six puck clutch (i got for my current setup, however i think i will have to step it up for the turbo). the clutch is F1 Racing, the only reason i got it is bc my friend got one just like it and its been holding up great on his b16 w/100 shot. the flywheel is a 7.5 lb Findanza my turbo should be here in about a week or so and same with the Eagle Rods
THE VICTIM
JE 9:1 Pistons
Fidanza 7.5 lb Flywheel
F1 Racing Stage 3 Six Puck Carbotic Clutch
UPDATE 8/16/06
GT35r
Type S BOV
Eagle H Beam Rods
UPDATE 8/20
CP 81.5mm 9:1 pistons to replace the JE's i have
UPDATE 8/22
ARP Headstuds
Cometic 81.5mm Headgasket
UPDATE 8/23
Hondata Intake Manifold Gasket (schweet)
UPDATE 8/23 #2
UPDATE 8/25
water pump, itr oil pump and timing belt
UPDATE 9/8
Padawon PS removal kit
slowly but surely, off to the machine shop
UPDATE 10/21
Some machine work done, still in progress
UPDATE 11/13
finally back from the machine shop, kinda assembled....
UPDATE 11/15
got the block and head painted and started "final assembly"
UPDATE 11/19
UPDATE 11/26
motor is completely assembled and ready to drop back in
UPDATE 11/28
motor finally back in, just gotta wire everything up and whatnot
UPDATE 3/7/07
yonaka fmic
UPDATE 3/15/07
aem fpr
UPDATE 3/27/07
stealthmode oil line kit
UPDATE 3/30/07
blaast performance 46mm wastegate
UPDATE 4/23/07
synapse ramhorn/dp/dt
UPDATE 4/24/07
greddy turbo timer
UPDATE 11/05/07
skunk2 cam gears
THE VICTIM
JE 9:1 Pistons
UPDATE 8/16/06
GT35r
Type S BOV
Eagle H Beam Rods
UPDATE 8/20
UPDATE 8/22
ARP Headstuds
UPDATE 8/23
UPDATE 8/23 #2
UPDATE 8/25
UPDATE 9/8
UPDATE 10/21
UPDATE 11/13
UPDATE 11/15
UPDATE 11/19
UPDATE 11/26
UPDATE 11/28
UPDATE 3/7/07
yonaka fmic
UPDATE 3/15/07
aem fpr
UPDATE 3/27/07
UPDATE 3/30/07
UPDATE 4/23/07
UPDATE 4/24/07
greddy turbo timer
UPDATE 11/05/07
skunk2 cam gears
