That's too low for me. I changed my mind. I'm going with the Pro-Kit again. Only because the S-Tech's are softer and drop lower. And I'm the main driver out of all my friends so having a full car will drop the car even more and thats something I'm not going to risk. I'd rather just stick with stiffer springs that don't drop as much.EK|B said:He's dropped on S-Techs and have 16" rims and it looks hella good imo.
http://www.clubcivic.com/board/showthread.php?t=68520
thanks. But, my drop is mis-leading. With the koni shocks, you can adjust where the spring sits according to the shock. I have mine on the lowest setting (the spring sits lower according to the shock, thus the car sits lower). this is actually the main reason im getting some ground control coils, so that I can leave the perch at the normal height (spring sit correctly) and still get the same drop as now, if not more. The reason behind it is simple, with the spring sitting lower, the shock cant really move as easily - theres force on it to begin with if you will. So, the prokit, although not as low as mine, will still give a fairly good drop AND it handles amazingly.amej8 said:Besides, Pro-Kit's look fine with 16's. Evan's (sk8shorty) car is a perfect example of how I want my car to look when dropped.
