Mugenej8
Guest
had the same problem try replacing your FITV if that doesnt fix the problem try replacing the IACV. i replace the IACV and it now it run perfect.
As for the FITV i dont have it on my TB so i cant say but many people take it apart and clean it up and it should work.
hope this help also try cleaning your whole engine spray water on it while the engine is runing make sure to cover your Distributor and air filter with a bag when doing this.
Also for your Intake manifold you might have some air holes you need to plug up i had to this with my skunk2 manifold it should be located in the back or my manifold toward the right side when facing the the engine.
