You can also try cleaning your headlight housings. A lot of times, oxidation builds up and kills the clarity, giving you a very weak and yellow headlight beam. You can use meguiar's Plastx and see if it helps. If the oxidation is really bad, you can look into wet-sanding them.
As far as HID's go, make sure you get the proper high/low ones with the electromagnetic moving bulb. They have shields on them and reduce the amount of glare to oncoming drivers. I wouldn't go any higher than 6000k though, otherwise your light output will be just as bad as stock, if not worse.
