read this its about sleeving http://www.clubcivic.com/board/showthread.php?t=32538
paagle said:Hondatec2042: I wanna run as much boost as possible without blowing up my engine. I was thinking of upto 20psi but if you say more is possible then I will certainly look into it. 9.1:1 was the advertised compression but when i checked with Ross Pistons, they claim it is 9.4....so will find out when i get them and have them put in.
Soldiaboy, thanks for the link but I have read up on that one already as I have been searching high and low to get more info on this. From what I gather, if i run up to 300whp then i should not need to sleeve my block but any higher than that then it would be required. I am going to see my mechanic tomorrow so I will ask him how much extra it will cost me to get it done, so that I dont have to keep getting my head opened up. This will hopefully bulletporoof it so that I can start with turbo and nos.
I wish I had the money to do this too dude....thank you Mr Visa......for letting me whoop my plastic fantastic!!
Ravage70 said:cuz the b16 is better
soldiaboy said:well i dont think he would plan on leaving the ls non built. why is it better? i was told it wasnt cause the vtec is not needed while the turbo spools and it only makes thing worse
paagle said:I have also been doin a lot of research and it does seem the vtec and turbo do work well together and are a better combination. I am still waiting on parts to be delivered so haven't had a chance to find out if i should get the block sleeved. From what HOndatech2042 is saying, i may not need to get the block sleeved unless i wanna run more than 25psi of boost. To start off with i was thinking in the region of 10-15psi and then start winding it up slowly as and when i have the money to upgrade the other compnents i.e. intercooler, lsd, throttlebody, NOS etc etc. What size of turbo do you guys think i should go for with this setup? to start off with i want approximately 300-350whp and then slowly take it up higher. After talking to you guys i have decided to take it up to 450-500whp if not higher seeing as it is possible. I am looking into the Quaife LSD but i think i will invest in that as i get closer to these figures as the cost is beginning ot get quite a bit now. I have been looking at T3/T4 turbos but not sure what to go for as many of the seem to have different size inlets and outlets as well as A/R which i havent got a clue what they are. I will have to start looking into what each of these things does in order to find the one with maximum power gains. I still want to keep this as my daily ride so not to go too over the top....(if 500whp isnt too over the top already!! )
paagle said:ok i have decided that i will not really take it too much past 350whp. This is to keep it reliable as my daily drive. I may look at increasing power later but for now i would prefer a car that has pretty good all round power and torque. My mechanic is conviced that the Stage 3 cams will be fine with turbo but i need to know what my best turbo option would be. I have been looking at different turbos but i am a little confused as to what to go for. From the information i have found, the t3/t4 may be a good option but apparently the GT25 would be better. However it seems the GT25 is good for low end power only. I am really confused as to what turbo i need to purchase to go with this kit so any help would be appreciated. Like i say i am looking for not much more than 350whp to keep things reliable but as you may know i have upgraded my internals to take a hell of a lot of boost. I have also just been told that my the pistons i have ordered will only have 8.5:1 compression. So obviously i need to balance this out in terms of boost.
paagle said:Hondatech2042: I have already purchased Skunk 2 Stage 3 cams as he recommended i get the wildest cams i can afford. The pistons are already on thier way over too but i am a little confused about them. According to Ross Racing, the compression should be 9.4:1 and thats why i ordered them but according to the guy who was selling them, they are only 8.5:1 on a B16a. I am convinced he is wrong which is why i still told him to send them. The product code is 99807 so you can have a search for yourself and see as i know 8.5:1 will be too damn low. Even if they are, my mechanic seems not too worried as the block will be machined plenty i.e. port polish, skimming, rebored to 81.5mm, balanced, sleeved etc etc and hence they will raise or lower the compression to get the maximum power out of the block.
