Irish92Drifter
Any one know if there good or not? i saw a set for my 91 Hatch that look pretty sweet....will they fit my stock Manafold?
Most of the yonaka exhaust I have seen are all catbacks. I have one too and im just about to hook it up but im waiting on my cat converter. I would replace the cat if I were you, if its no good. Do it right the first time. Goodluck broYEah i was an idiot... i ment to the Header... the only Problem i see is seeing if my Cat convertor is Good... or if i need to replace it... the exhaust System is only from the Catback... so idk what i should do... any Ideas?
you already bought the exhaust then? Heres a link for your year on magnaflow cats. The direct fit is always going to be more. You can always use your stock one too, that is if its still in good shape. I almost bought the magnaflow for mine but I found a used hi flow cat for alot cheaper such im on a budget.thanx... yeah only thing with that is i bought the kit...and now i need to find a Cat converter... idk what dia. i need or High or low flow.
