3/31/11 *Retune on page 3*
3/12/11 *H2B complete pg 3*
2/23/11 *H2B update on pg 2*
1/14/11 *Going H2B this winter*
I have a 96 civc hatchback with a fully rebuilt H22a4 all motor. Took me 6 months for the motor build and another 4 months for the suspension and brake upgrade on the car. Here it is it's finally done.
Built By Me
Motor:
1)port and polish the head & super tech valve guides
2)skunk2 pro 2 cams
3)skunk2 valves and springs
4)Skunk2 TI retainers
5)skunk2 cam gears
6) ARP head bolts
7)Hondata Im gasket
8) Cometic head gasket
9)Auto to Manual timing tensioner
10)Stock h22 crank
11)Darton sleeves
12) CP pistons 11.5:1CR 88mm bore
13)Eagle rods
14)ACL bearings
15)ARP main studs
16)70mm Omni TB
17)Euro-R manifold
18)RDX 410cc injectors
19)AEM fuel pressure regulator
20) Custom Fuel rail By Rosko racing
21)255 walbro fuel pump
22)OEM oil pump, water pump and all gaskets and belts
23)Evans tuning on hondata s300
Brakes and suspension:
1)Front and rear SI brakes DBA rotors & Hawk pads
2)Front SI sway bar
3)Front Integra type r strut bar
3)Rear CTR sway bar
4)Rear ASR polished subframe brace
5)Skunk2 polished LCA's
6)Koni yellow shocks with custom spring rate Ground control coilovers
Exerior:
CTR front and rear lip
CTR wing
CTR grill
SI side skirts
OEM fogs
Inerior:
RSX seats
CTR steering wheel
CTR gauge cluster
Let me know what you guys think
thanks
yvette
Heres the tune Video at Evans tuning
The CTR stickers where on the car when i bought it they will be removed shortly.
http://www.youtube.com/watch?v=icbPv4f4bx8
Here's the vid of the build
http://m.youtube.com/index?client=mv-google&xl=xl_blazer&desktop_uri=/&gl=US#/watch?xl=xl_blazer&v=IYVfnDGO8Gg
First start up of freshly rebuilt H22a4 running on a Stock h22 Base map.
http://www.youtube.com/watch?v=JIvHIb-zTuE
**1/14/2011 GOING H2B THIS WINTER** STAY TUNED!!!
Built By Me
Motor:
2)skunk2 pro 2 cams
5)skunk2 cam gears
6) ARP head bolts
7)Hondata Im gasket
10)Stock h22 crank
11)Darton sleeves
13)Eagle rods
14)ACL bearings
15)ARP main studs
16)70mm Omni TB
17)Euro-R manifold
2)Front SI sway bar
3)Rear CTR sway bar
Exerior:
CTR wing
CTR grill
SI side skirts
OEM fogs
Inerior:
RSX seats
CTR steering wheel
CTR gauge cluster
thanks
yvette
