1996 civic d16z6 p2p ecu HELP.
noeljay
hi i bought a 1996 civic hatchback with a d16z6 and a p2p ecu. theres no vtec cause someone told me i need a p28, now when i go and buy the p28 is it going to just plug right in? i know the vtec wont cause its not wired yet.
heres my question:
what all do i need,what is the right wire harness and ecu for this motor and chassis combo. do i need a wire harness conversion or anything extra?
xxsenceo89x
aka superman
if you have a p2p, theres gunna be a cel. the p2p is an obd2 vtec ecu from a d16y8. the y8 ecu looks for knock sensor, vtec pressure and other s**t. just run the wires from the sensors to the ecu
SiBlue_EK
save the SOHC
heres my question:
You will need the p28 ecu and also a conversion harness to convert to obd1. I believe your car is using obd2a right now.
As far as VTAK goes, you will need to find the ECU pin out for the VTAK solenoid and the VTAK pressure switch.
This can be easily plug and play if you get yourself an EX wiring harness
NFR_AP2
damn, if only you had a p30, id trade you for the p28 i have...
