there are like 7 bolts. open the hood. there are three there. open the door, there are two there (one at the top and one at the bottom) there is one under the inner wheel well right under the corner light and one more on the bottom of the fender that holds the front part of the side skirt the the body. also you need to detatch the inner wheel well from the fender. ( just pull the center part of the screw type clip out and then the whole clip will come out.) that should be it. ill see if i can find a pic in my manual.
EDIT: nope. no picture in the manual.
