D2 Racing RS Coilover System
The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts*. Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.
Staring at $812.50 Shipped
http://www.tunersports.com/products/d2-racing/d2-racing-rs-coilover-system_110.html
D2 Racing Lower Rear Control Arms
D2 Racing lower control arms reduce unsprung weight by over 30% over your stock units. Constructed of aircraft quality 6061 aluminum and powder coated with the distinctive D2 ceramic coated purple. D2 Racing lower control arms also solve rubbing problems that can result in lowered cars with wider tires.
Staring at $146.25 Shipped
http://www.tunersports.com/products/d2-racing/d2-racing-lower-rear-control-arms_111.html
D2 Racing Toe / Camber Kit
D2 camber and toe kits provide adjustment from 0-3", a must for lowered cars. Steel mounts, polyurethane bushings and aluminum body provides the ultimate in strength, performance and weight reduction.
Staring at $104.00 Shipped
http://www.tunersports.com/products/d2-racing/d2-racing-toe-camber-kit_112.html
D2 Racing Quick Release
D2 ball bearing steering quick release allows you to take your steering wheel on and off in seconds. This kit accepts any 6 hole hub adapters and popular aftermarket steering wheels (Sparco, MOMO, Nardi and more).
$84.50 Shipped
http://www.tunersports.com/product/d2-racing/d2-racing-quick-release-d2-qr_797.html
$84.50 Shipped
