philbrickvw
Hello folks - I normally fix VWs but I'm helping a friend with her 1991 Honda Civic DX. Discovered a strange wiring problem.
I was checking out her rear window wiper motor that isn't working. Here is a list of info about all the wiring in the rear hatch. All fuses are working but I have not had the chance to check relays.
- Only one of the wiper motor wires gets power. If I recall correctly, it is the solid green wire. This wire only gets power when the rear wiper switch is on and the defroster button is pressed.
- The rear brake light does not work with the brakes but stays on when the rear defroster switch is on
- the rear defroster does work
- I checked the wires as best I could. The only break I found was it appears the factory crimped the ground wire from the defroster to the ground on the wiper motor.
Any ideas how I can get the rear brake light back? Could the problem be with a relay?
Thanks in advance!
Thanks in advance!
