Custom Turbo 7th gen
joe7987
Moderator
Yea.. definitely sounds nice. It's gonna be fun. =oP
2k5civic
i hate imports...! siiike
the thing i would want to know is this..
since im so illiterate when it comes to building a self custom turbo kit for my D17A2 .. if anyone can link or paste or wutever, the parts needed for a full turbo kit .. everything basic. pipes, intercooler, ect.ect.
joe7987
Moderator
taken from 7thgencivic.com
Bare Essentials
Turbo (T3 Super 60 / T3/T4 W/ Internal Wastegate ) $200-$600
Oil feed line $50-$80
T-Tap for oil feed line to hook up to factory sensor $5-$15
Fitting for T-Tap to screw into factory sensor $1-$5
Fitting for feed line to screw into T-Tap $1-$5
Fitting for oil feed line to match up with turbo $20
Oil return line $20-$50
Oil return fitting for the oilpan $5-$30
Fitting for oil return line to match up with turbo $20
Manifold (Maxrev/ Dezod/ Turbo Manifold ) $100-$1000
Manifold to turbo Gasket $1-$5
Downpipe (Custom / Maxrev) $100-$700
Downpipe to turbo Gasket $1-$5
Downpipe to exhaust Gasket $1-$5
Piping / Hoses / Couplers for your charge pipe $50-$200
4 QTS of new oil ( Synthetic is recommended) $10-$50
Honda Gasket Sealant - $5
Recommended Parts
Colder Spark Plugs ( Denso IK20 ) $40-$60
External Wastegate ( 38 MM Tial Wastegate ) $150-$200
Vacuum Line for Wastegate $1-$2
T-Tap for Vacuum Source $1-$5
Wastegate to turbo gasket $1-$5
BOV ( Greddy Type S BOV ) $80-$200
BOV Flange $10-$40
BOV Gasket $1-$5
Vacuum Line for Blow off Valve $1-$2
RSX Injectors ( 320 CC ) $20-$300
Longer bolts for the RSX Injectors to the Fuel Rail $1
Intercooler ( None Specified ) $50-$600
Piping / Hoses / Couplers for Intercooler set-up $200-$1000
Fuel Management ( V-AFC / S-AFC ) $100-$300
Missing Link $20-$50
Air Filter for Turbo Intake Pipe $5-$30
Manual Boost Controller $30-$100
No Shortcuts
Modded Fuel Rail for Return Fuel Set-up $20-$70
Fuel line to run into fuel tank (Stainless Steel) $20-$100
Fitting for Fuel Pressure Regulator to Fuel tank $5-$20
Fitting for Fuel Line to Fuel Tank $5-$20
Fitting for fuel tank $5-$20
Hoses for fuel tank $10-$100
Clamps for fuel lines in tank $25-$20
Fuel Pump ( Walboro 255 LPH ) $50-$150
Boost Referencing Fuel Pressure Regulator ( Aeromotive ) $100-$200
Vacuum Line for Fuel Pressure Regulator $1-$2
Fitting for Fuel Pressure Regulator fuel line to Fuel Rail $5-$20
Fitting for Fuel Rail to Fuel Pressure Regulator $5-$20
Plug for one side of Fuel Pressure Regulator $5-$20
440 CC Injectors ( RC Engineering) $200-$400
Afermarket Clutch ( Exedy Organic/ ACT Street Disk ) $150-$300
Fuel Management ( Greddy E-Manage ) $150-$400
Greddy Pressure Sensor $50-$100
Greddy Pressure Harness $10-$40
Greddy Ignition Harness $10-$40
Greddy Injector Harness $10-$40
Wideband ( AEM UEGO / Innovative LM1 / PLX M-300 ) $250-$800
T-Bolt Clamps for Piping $50-$100
Electronic Boost Controller ( Profec E/B ) $100-$600
Vacuum Line for Boost Controller $1-$2
Vacuum Manifold ( Golden Eagle) $20-$50
Fittings for your Vacuum Manifold to Vacuum Sources $5-$30
Magnetic Oil Drain Plug $10-$60
2k5civic
deeeezamn!! joey you the man.
got_sake?
1.7 ltrs of fury!!!!
Bare Essentials
Recommended Parts
BOV Flange $10-$40
BOV Gasket $1-$5
No Shortcuts
I was just getting ready to paste this. This info is coutesy of Hwoody77 on 7thgencivic.com! That's a pretty detailed list he threw up! The T3 turbo is bigger than a T25 right? anyway....good lookin' joe!
DMunny
Matt.
I'd recommend a manual boost controller over a electronic... electronic tend to be inaccurate some times... Ever says so in the manual.
got_sake?
do have any specific recomendations?
joe7987
Moderator
Yes, a T3 is bigger than the T25 (about 90% certain on that). I'm not sure if I wanna go with a T3 or a T3/T4 yet. Any advice from anybody?
Matt.
I'd recommend turboXS boost controllers, tial waste gates, and turboXS or greddy BOV's
Matt.
a t3 super 60 is the best turbo for our car. Making max power between 3500 and 4000 rpms. t25's are not entirely bad for our cars, because they do tend to spool fast. But if you want a fast spooling turbo with a t3 flange which will allow you to upgrade, pick up a t3 (.42/.48 )
joe7987
Moderator
awesome, thanks for the advice!
Matt.
faster spooling turbo's tend to make power faster, like around 3000 suffer less turbo lag, but hurt in power.
joe7987
Moderator
Yea... I know the little turbos spool up quick.... but I want something that'll be capable of giving me a bit more power. That's why I figured T3 or T3/T4
Matt.
A t3/t4 is wayyy to big on our little engines.
Rick James
Going-West said:
there was a girl on CC forever ago who had a boosted 7th gen, she said it still wasn't very fast though. Maybe the d17 doesn't respond as well to boost as usual hondas do I'm not sure, thats a good question :???:
you talking about the girl with the 7th gen si that blew her motor?
EM1_ProJect
Yeah...it's boosted
Joey just buy a brand new turbo, find a junked intercooler, manifold, etc. and bend some piping. it shouldnt be any different than my crappy little setup. cheap, and just as fast !
Matt.
there is a guy on homemadeturbo.com who said if I can get him a head flange like off a header or something He can make a custom manifold for pretty cheap.
joe7987
Moderator
I plan on doing that.. it's just a matter of making sure I do it the right way so that I don't have to lose AC or PS or any of that good s**t. lol.
Matt.
I bought h22 pipes... They are custom fit to my car. You can make anything fit.
