i second that, the cams are longer than the zc ones. it will not workneojen said:somehow I doubt cams for a b16 will work in a zc..
who won?91 Hatchie said:i raced a buddy of mine with a B16a2 motor, we where runnin about a buck twenty (120).
Going-West said:i dont know much about those engines, but from my experiences w/ a dohc b16 i would take a non-vtec twin cam over a vtec single cam, even if they have the same power.
damn street racers, lol.91 Hatchie said:i raced a buddy of mine with a B16a2 motor, we where runnin about a buck twenty (120).
haha, you crazy bastard91 Hatchie said:we kep up with each other. it was down 175 in marylandy, we where heading to the mall on lunch break from school.
ryan89crx said:the z6 has way more building options than the zc. tons of companies make aftermarket rods, pistons, cams, everything for the single cam. but with the zc your options are limited.
both are good motors, the SOHC will be easier to upkeep and maintain as well as pull power from if your a "noob"sherfield2002 said:well i may be wrong but the aftermarket rods and pistons for the sohc d-series will work in the dohc zc. they are d-series blocks too so that shouldnt be an issue. check out www.thezcr.com if u need any more info on the zc. also i have a dohc zc in my 89 hatch and it will take my buddys 92 ex with a d16z6 pretty easy if that means anything
i hope your not talking about the 88-89 teg motor, which is the d16a1, which is the only US dohc 1.6 litre motor.4dr said:both are good motors, the SOHC will be easier to upkeep and maintain as well as pull power from if your a "noob"
this is of course depending on if you choose to go to OBD-I(for the vtec) or how you decide to manage the "vtec' cross over as theres many ways and not all are created equal.
if your leaning more towards the SOHC than the DOHC D16 in a an "88-91" chassis cars, you should maybe consider looking it the "non vtec" d16a6, its a good motor.
but yes, you wont posses the "vtec bling"....
mounts are wrong, correct?jspeczcturbo said:that and the d16a1 won't work in our gen civic anyways, lol.
yes that is correct.ryan89crx said:mounts are wrong, correct?
