B18C1
* VTEC
* Found in:
o 1994-2001 USDM Integra GS-R (DC2/DB8)
+ Displacement: 1,797 cc (109.7 cu in)
+ Compression: 10.0:1
+ Bore: 81 mm (3.189 in)
+ Stroke: 87.2 mm (3.433 in)
+ Rod Length: 137.9 mm (5.429 in)
+ Rod/Stroke Ratio: 1.58
+ Power: 170 hp (125 kW) @ 7600 rpm
+ Torque: 128 ft·lbf (175 N·m) @ 6200 rpm
+ Redline: 8100 rpm (Fuel cut-off @ 8200 rpm)
+ VTEC Engagement @ 4400 rpm
+ Transmission: Y80(No LSD) 5-Speed Manual Transaxle
B18C5
* VTEC
* Found in: USDM DC2 Acura Integra Type-R (Integra Type-R)
o 1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
* Displacement: 1,797 cc (109.7 cu in)
* Compression: 10.6:1
* Bore: 81 mm (3.189 in)
* Stroke: 87.2 mm (3.433 in)
* Rod Length: 137.9 mm (5.429 in)
* Rod/Stroke Ratio: 1.58
* Power: 195 hp (145 kW) @ 8000 rpm & 130 ft·lbf (180 N·m) @ 7300 rpm
* Redline: 8400 rpm (Fuel cut-off @ 8500 rpm)
* VTEC Engagement @ 6000 rpm
* Transmission: S80 w/LSD
