joe7987
Moderator
K-Series Specs
Well, I figured this would be some good reference material for all of you K-Series swappers. This should also help you to decide which engine you'd like to swap in. If you have anything to add, post away and I'll append as necessary. Feel free to help me fill in the question marks.
Special thanks to ojay for helping out with this.
K20A3
7th gen Honda Civic Si / base model Acura RSX
2.0 L DOHC
6800 RPM Redline
160 hp / 132 lb - ft tq
9.8:1 compression
K20A2
Acura RSX-S
2.0 L DOHC
???? RPM Redline
200 hp / 142 lb - ft tq
11:1 compression
K20A
Honda Integra Type R
2.0 L DOHC
???? RPM Redline
220 hp / 150 lb - ft tq
11.5:1 compression
K24A1
Honda CR-V
2.4 L DOHC
???? RPM Redline
160 hp / 162 lb - ft tq
9.6:1 compression
K24A2
Acura TSX
2.4 L DOHC
7100 RPM Redline
200 hp / 166 lb - ft tq
10.5:1 compression
K24A4
Honda Accord / Honda Element
2.4 L DOHC
???? RPM Redline
160 hp / 161 lb - ft tq
9.7:1 compression
K20Z1
2005 RSX - S
2.0 L DOHC
7800 RPM Redline
210 hp / 143 lb - ft tq
??:1 compression
K20Z3
8th Gen Civic Si (FG2)
2.0 L DOHC
8000 RPM Redline
197 hp / 139 lb - ft tq
11.0:1 compression
Head Info
A4 head
2 cams lobes on the intake
1 cam lobe on the exhaust
EGR Porting
A2 head
3 cam lobes on intake and exhaust cams
EGR Porting
A1 head
2 cam lobes on intake
1 cam lobe on exhaust.
K20A3
2.0 L DOHC
6800 RPM Redline
9.8:1 compression
K20A2
Acura RSX-S
2.0 L DOHC
???? RPM Redline
11:1 compression
K20A
2.0 L DOHC
???? RPM Redline
11.5:1 compression
K24A1
Honda CR-V
2.4 L DOHC
???? RPM Redline
9.6:1 compression
K24A2
Acura TSX
2.4 L DOHC
7100 RPM Redline
10.5:1 compression
K24A4
2.4 L DOHC
???? RPM Redline
9.7:1 compression
K20Z1
2005 RSX - S
2.0 L DOHC
7800 RPM Redline
??:1 compression
K20Z3
2.0 L DOHC
8000 RPM Redline
11.0:1 compression
Head Info
A4 head
EGR Porting
A2 head
EGR Porting
A1 head
