K series specs: Reference for Swaps
King Bob
The life'o Riley
Hey joe please post up the 06 Si info
K20Z3
8th Gen Civic Si (FG2)
2.0 L DOHC
8000 RPM Redline
197 hp / 139 lb - ft tq
11.0:1 compression
joe7987
Moderator
K20Z3
2.0 L DOHC
8000 RPM Redline
11.0:1 compression
Will do. Thanks for the info! =)
Pineapples
Yes, I'm a n00b. Bite me
I've gotta say even tho I feel such a n00b when I ask this.. I know 9 is low compression, and 11 is high. What about 10? Is 10 a good number to get a turbo charge?
j_fukin_t
damn 11:1 compression, 10's are tolerable
pon55
Compression ratio is increased as you boost. somewhere i have a chart, but can't find it,DA
anyway, the higher the boost you want to run,the lower the compression ration (NA) has to be.
An example,if i remember right, is 9 to 1 at 8 psi = 11.5 to 1, so if you turbo an 11 to 1 = BOOM
Dulce
Ok I have a question, since basically every other K-series engine can be swapped into the 7th Gens, what about the new RDX turbocharged motor, the K23A1. Does anyone know if that would be a K swap we could do?
Andrey
All Honda K-series engine specifications
K20A (2007- Honda Civic Type-R FD2)
K20A (2001-2005 Honda Civic Type-R EP3)
K20A (2001-2006 Honda Integra Type-R DC5)
K20A (2002-2006 Honda Accord Euro-R )
K20A2 (2002-2004 Acura RSX Type S, 2002-2005 EDM Honda Civic Type R EP3)
K20A3 (2002-2005 Honda Civic Si EP3)
K20A3 (2002-2006 Acura RSX Base)
K20Z1 (2005-2006 Acura RSX Type S)
K20Z2 (2006+ CDM Acura CSX, 2006+ JDM Honda Civic)
K20Z3 (2006+ USDM Honda Civic Si)
K23A1 (2007+ Acura RDX)
K24A1 (2002-2007 Honda CR-V)
K24A2 (2004-2005 Acura TSX )
K24A2 (2006-2007 Acura TSX )
K24A3 (2003-2006 JDM/AUDM/EDM Honda Accord)
K24A4 (2003-2005 Honda Accord, 2003-2006 Honda Element )
k24A8 (2006-2007 Honda Accord)
Differences between k20a's.
DC5 k20a has better exhaust manifold than EP3 K20a thats why it makes 5 hp more. Accord Euro R has RBC intake manifold (same as found in 06+ Civic Si) versus EP3's and DC5's PRC intake mani. Euro R's oil pump is also is equipped with balancer shafts which make engine smoother but rob some hp.
Differences between K20A3's.
EP3 K20A3 comes with PRB intake manifold from RSX-S K20A2. Base RSX k20a3 on the other hand has plastic intake manifold. EP3 has oil pump that is equipped with balancer shafts which make engine smoother but rob some hp. DC5 k20a3 has same oil pump as RSX-s K20A2 and it is therefore more suitable for high revs. Although both cars come with 5 speed manual final drives are different in two cars. EP3 has 4.7 fd and DC5 comes with 4.3 fd. This makes EP3 have shorter gear ratio. EP3's intake manifold makes enigne more suitable for mods and gains are bigger, but on paper it makes less low end tq, that is why there is 9 lb-ft difference between two cars.
