My 96 DX Hatch build (56k warning)
TheCrazy1
i-VTEC addict
I just went through the whole build and I love it! Can't wait to see more!
ct96ek
Exhaust - I am looking for something a little more streetable and quiet so...
Tanabe Super Medalion
Apexi WS
RS-R ExMAg
ImportFan1
Super Moderator
RSR or the Tanabe. I am bias bc I had the Exmag on my old coupe.
ct96ek
So I have a bunch of local H22A4s to choose from and can't decide. It might be easier to stay with a 97-98 because I can stay OBD2A and use most of my civic harness. Most of the 97-98s around here have 100,000 to 130,000 miles on them. Or I can get an engine with better miles in an OBD2B, get a new harness and buy a OBD2B to ODB2A jumper harness. I was planning on having the engine rebuilt but if I got a motor with under 60,000 miles on it I probably wouldn't. I want to try and pick up the engine tomorrow so I need to decide.
ct96ek
Tomorrow or Friday I am picking up a 1998 H22A4 engine, trans and shifter assembly with 84,XXX miles on them for $2,000
Omar EJ6
Let me know how it goo, when you get it ....
A local friend is selling me an H22A for 3,000 it has a lot of things done to the engine but, Im still thinking about it ... My car is an auto trans ....
ct96ek
First picture after we got it off the truck
First look inside - not bad but not great either
Looks like one hell of an oil leak - cam shaft seal maybe? and some battery acid I think
And of course they smashed the tps
Inside of the valve cover looks a little burnt
ct96ek
Back in the garage
Good location for the fuel filter?
I never showed how I routed my washer fluid lines - through the hood and out into the fender.
I love the wheel offset
Carbon cargo cover
Replacement exhaust shield for ebrake cables
H22 Shifter and cables
Cable bracket I can use as a template
Test fitting shifter
Square peg round hole
I think this location will work- I wish I did this when the dash was out
Brake hoses and fuel feed line waiting - I need to tuck my computer harness haha
ct96ek
Starting work on the shifter
template created
meet my angle grinder
cardboard to stop the sparks
fits down inside
cable hole cut
mocked up
time to fab up the box/cover for under the car
just using aluminum so we can bend and cut it easily
good start
first part in place
sides on
spray painted
cable opening - I am not sure if the grommet should be on the inside or out
cables in the right place - a little long but that is ok
all done
BLK VTi
Apple Bottom Booty = FTW
f**k a Karcepts Shifter Mount Kit
Your the next best thing
Good build man, I got to make sure I keep my eyes peeled on this
:word:
ct96ek
Ordered yesturday
Autometer GaugeWorks Mounting Solutions - cluster pod
Autometer Z-Series Gauges tach 2 1/16"
Autometer Z-Series Gauges voltage 2 1/16"
Autometer Gauge Accessories blue leds
BLOX Radiator Stay black
Mishimoto Performance Radiators
Mishimoto Radiator Fan 12"
Mishimoto Radiator Fan mounting kit
BLOX Throttle Position Sensor (TPS)
ct96ek
Here is a closer shot of the thick layer of grime sitting on the transmission. Notice the battery acid.
About a hour later things were looking much better. I used simple green and brake cleaner with lots of paper towels.
Getting there
Good thing about the oil is that it kept everything underneath protected
Still have a lot of work to do in this area. I have to unbolt a lot to gain better access.
ct96ek
I love before and afters but I guess this is a before and during
Where I started
During
ct96ek
Does anyone know if I will need the in-line clutch fluid damper shown as #22?
I might just go with stainless braided line from the master to the slave.
I also need to figure out what radiator hoses to use and what heater hoses to use.
ct96ek
Intake manifold, plug wires, coil, etc....removed from the block
Wire harness labeled and removed
Getting shiny
First look at the valves and intake side of the head - lots of nasty build-up but not on the valves. I spun the crank and all the valves opened and closed nicely and it sounds like great compression
Better shot of the back
mugengirl
original mugen whore
Goodluck with the project! Looks like you are getting well under way.
ct96ek
Tonight my buddy and I will probably-
-take off the headers
-drop the oil pan and clean / check out how everything looks from underneath
-mount the cat-back system
-fix the grommet on the shift cables
