I have up for sale a 1992 6/4 talon with lsd rear-end. It has about 2000 miles on the rebuild it has...
ENGINE
Arias 9:1 compression pistons
New rings
all ARP hardware
90 BIG shot peened rods
Polished Crank
STD bearings
New valve seals
New valve guides
New T-belt Tensioner
New T-bealt bearing
New T-belt
Cometic 4 layer head gasket
BS eliminator shaft kit
BOLT ON
Ported exhaust outlets on head
New 14b turbo
2g exuast manifold (ported)
02 houseing highly ported
New gaskets for head and intake mani
New oil pump
TRANS
ACT 2100 clutch kit
800 miles on new Tranny
OTHER
Detion J-pipe
Big Brake upgrade (not installed)
Polished valve cover
Polished fuel rail
SRP BC
Magnaflow 3''inch inlet muffler
3'' Stright back
3'' downpipe
HARD upper inncooler pipe
SS Oil lines
New BPR7es plugs
2g cover plate (mas)
2g mas
Super HKS-ARF w/harness
AUTO METER Boost gauge
AUTO METER Oil PSI gauge
New slave cylinder
New tie rod ends
4 New axles
New yoke in the drivetrian
Engine oil MOBILE-1 15w-50 extended preformace every change.
All drivetrain FLuid is 80-90w with GM sycro mesh
Some Semi back points about the car.
*It has no rear interior
*minor hail dmg
*windows have a hard tiem going up stright
*One small oi lleak I have the gasket to fix it jut not installed yet.
*dash in a little rough shape but I will include a Mint condition dash
*E-brake is weak
*Belt sqwack at start up (alternator belt)
Besides that its a great runner Always starts, Its set at 10psi still breaking it in this car used to be white but was repainted a Dark grey tan with flake.
I cant have a fun car anymore seeing as I have a kid on the way so I need a more family type of car.
Will consider Trades with cash for a family car looking for a civic or somthing along those lines. thanks for looking
PRICE: 3000 obo
you can also try emailing me at crxsiterror@yahoo.com
ENGINE
New rings
all ARP hardware
Polished Crank
STD bearings
New valve seals
New valve guides
New T-bealt bearing
New T-belt
BOLT ON
New 14b turbo
New oil pump
TRANS
ACT 2100 clutch kit
OTHER
Detion J-pipe
Polished fuel rail
SRP BC
3'' Stright back
3'' downpipe
SS Oil lines
New BPR7es plugs
2g mas
New slave cylinder
New tie rod ends
4 New axles
*minor hail dmg
*E-brake is weak
PRICE: 3000 obo
