1993 civic idle issue
Firstgentoyota
Runs good, idles up and down at idle, when driving idle is fine only when sitting. I have changed all sensors still have the problem any help would be huge. Thanks
91EF01
Try replacing the ICM
5SpeedEJ6
What sensors are you talking about specifically? I doubt you've changed ALL sensors in the car, that would insanely time consuming and not very smart anyways. Whenever I heard an idle issue I tend to lean towards a vacuum leak, have you checked for that?
Restotech
Idle going up and down is usually the iacv (idle air control valve) but can also be a vaccum leak or fast idle thermo valve. There are some other possibilities but these are the most common.
Firstgentoyota
Ive changed the idle air control valve ive gone over all the vacume lines aswell nothing changed or helped at all.
Mr.Baker
Mr. Search
Do you hear a whistling sound under acceleration?
Intake manifold gasket could cause idle issues.
Motoammo
I went threw this same thing do me a favor and take your radiator cap off and start the car
