Manual transmissionAuto transmission?
I get 28mpg now a ground to the alternator was broke that can make it consume more fuel, and I have a cel code it's a massive Leak in the evap system and I'm thinking it's the gas cap because seal is a little rotted and has a crackCheck that spark plugs are properly gapped. Are they the plugs recommended in the Owner's Manual?
If you unplug an engine sensor to trigger a CEL code, does the code remained stored in the ECU after the ignition key is turned off?
If you connect an OBD2 code reader, do all sensors report as ready?
