A Honda crx
89 Crx 1.6 si code 7, nothing will fix, choking out, runs rich, please help
I have tested the iac, cleaned the intake, new plugs, wires, run and set two tps sensors, they glide from .45- 4.6 v on average. tested the ground wire seems good. solenoids in the iac and the other by pass sensor on the back of the intake are good.
I read that four things can cause problems here. iac pluged, iac failure, oxygen sensor fail, and temp sensors reading the engine as hot.
Iac was clean, o2 sensor has been swapped, iac works, haven't changed the engine temp sensor but that seems far fetched
Q: Iac- Idle are control. When I tested this on a battery, it opened wide, then stayed open until I removed it from the battery/ 12.3...Volts all good. I tested the cars plug that goes to the iac, it read 12.2... All good, thats to be expected. I plug it in, and it opens then closes. Why would it do that? Is this my problem, when a load is put on the iac, it doesn't stay open? what is the source of this kind of issue, and the tps test procedures tell me to replace the cpu, does the computer ever fail and have to be replaced.
Car history, ran good until overheated and threw a rod, sat for two years, engine swap, started good, then this...
Please, someone help me! Thanks.
