AEM Digital Wideband Air / Fuel Gauge
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
•Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
•Does not oscillate AFR reading like narrow band sensors
•No laptop required for monitoring!
•Bosch sensor included
•Accurate to 0.1 AFR
•Reads in AFR or Lambda via a switch in back of gauge housing
•24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
•Integrated three-digit display reveals AFR or Lambda in real time
•User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
•Serial data stream included for output of AFR (RS 232)
$207.21 Shipped
AEM Analog Wideband Air / Fuel Gauge
AEM’s wideband air/fuel gauge unites unsurpassed accuracy, speed and control with an easy to read, analog interface. The AEM wideband also offers a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.
The system features a Bosch sensor with an accuracy of .1 AFR, making it among the fastest and most accurate widebands available. The backlighting is user adjustable to 7 colors, (white, blue, green, red, orange, light blue, and aqua), allowing users to easily match the wideband gauge to most factory gauge clusters.
•Accurate to .1 AFR
•Adjustable backlighting via a dial on the back of the gauge
•Two status lights for error detection and operating status
•Available in white or black gauge faces
•Includes black and silver interchangeable bezels
•320 degree viewing area for unsurpassed resolution
•Includes Bosch sensor for optimum accuracy and reliability
•0-5v analog output included for use with data loggers and virtually any engine management system
$207.21 Shipped
$207.21 Shipped
•Accurate to .1 AFR
$207.21 Shipped
