so i won a viper 2-way pager and remote starter alarm in a contest. anyways im trying to save myself around 300 bucks by installing it myself but i'm totally lost as to where i wire into. im aces when it comes to anything mechanical with a car besides electronic aspects unless its as simple as a subwoofer or something. so im looking for some help on what harness' to splice into, what wires do what in the harness, and pretty much how to wire this bad boy up. (please keep stupid comments to yourself, this thread is strictly for help)..
anyways ill make a list of each harness for the alarm and where they need to go. maybe someone can give me some help.
main harness (12 pin connector)
1 (-) 200ma AUX/trunk output
2 (+)12v DC constant output battery
3 (+)Siren Output siren positive wire
4 Parking light isolation wire-pin 87a of onboard relay red/black wire, at fusebox or drivers kick panel
5 (-)chassis ground obviously a ground wire
6 (+)door trigger input light green/red wire, in drivers kick panel
7 (-)trunk pin/ instant trigger input (N/C or N/O)
8 (-) door trigger input (N/C or N/O) not sure, just ground?
9 (-)200ma done light supervision output considering attaching to negative of dome light plug?
10 (-)remote start/turbo timer activation input
11 parking lights output red/black wire, @ fuse box or divers kick panel
12 (-)500ma ground when armed output
door lock, 3 pin connector what do i do since i have manual doors? not use it?
1(-) 500ma unlock output green/red wire, @ 2-pin blue plug behind fusebox
2not used
3 (-)500ma lock output green/white wire, @ 2-pin blue plug behind fusebox
harness #2, 18-pin connector
1 (-) 200ma OEM alarm disarm output not applicable?
2 (-) 200ma aux 4 output not applicable?
3 (-)200ma OEM alarm arm output not applicable?
4 (-)200ma aux 2 output not applicable?
5 (-) 200ma aux 3 output not applicable?
6 (-) 200ma aux 1 output not applicable?
7 (-) deisel wait to start input not applicable?
8 (-) 200ma horn honk output blue/green or blue/red wire, @steering column harness
9 tachometer input blue wire, @ 2-pin plug near dizzy
10 (-) 200ma status output not sure where negative is
11 (-) 200ma flex relay control output
12 (-) 200ma accessory output not sure where negative is
13 (-)200ma starter output not sure where negative is
14 (-) 200ma ignition 1 output not sure where negative is
15 (-) hood pin input (N/C or N/O) wire goes to the hood pin sensor i got?
16 (-) 200ma 2nd status/rear defogger output
17 (+) brake shutdown input green/white wire, @ switch above brake pedal
18 (-) neutral safety input negative of neutral safety switch?
harness #3 10-pin remote start connector
1 (+) ignition 1 input black/yellow wire, ignition switch harness
2 (87) flex relay input (30a fused)
3 (+) accessory output yellow wire, ignition switch harness
4 (+) starter output (car side of starter kill) found a site that says the starter wire is black/white, so that colour on this side of the starter?
5 (+) starter input (key side of starter kill) black/white wire on this side of the starter?
6 ignition 1 input (30a fused) black/yellow wire, ignition switch harness (same as pin 1 on this connector??)
7 (30) flex relay output
8 (87a) flex relay input
9 accessory/starter relay input (30a fused) black/white wire from key side of starter kill?
10 no connection
please help me out. i searched and filled in what i found, but i want to verify it and complete the rest as well
2not used
10 no connection
