yes you can swap in a K20a3, you just have to gather the necessary parts for the specific motor you're wanting to drop in . All K series motors can be installed into the EM2 chassis.well this is my only options either k swap or boost so theres no other motors i can choose from. my only question would be if i can use the k20a3 motor from 02-05 si drop it just fine in the em2. im only confused since the shifter in the si is placed differently than most stick shift cars. i found a k20a3long block with 65k for $500 obo
Not with an a3 motor and trans and just getting the car running.doing a k20 swap would cost more then your cars worth.
No, there is still more involved like the rsx subframe. Google the swap and youll find full lists pf what's needed.only reason why don't want a ep3 is bc i need more space for me and my son so i choose em2 for the convenience of size, as far as parts needed for the swap would it only be the engine, transmission , ecu n clutch line?
