I know people have boosted 7th gen civics, but has anyone boosted a non-vtec 01 LX sedan or would it be basically the same as boosting the vtecs or coupes? If so what was your setup, how much did you end up paying, and what gains did you get?
if your on a tight budget i dont recommend you boost. you will run into problems and it will cost money to fix them. and if you dont have the money for to fix it then your basically s**t out of a carDulce said:Yea, im not going for big power right now, im on a tight budget, just want some extra power for a while. It should be alright to run 6-10 lbs of boost with the stock internals and stuff without blowing anything right?
This man is wise.... 5-7lbs or about 180-200whp is about all that motor will take bone stock with any form of reliability (good tune needed of course).Shiznit said:if your on a tight budget i dont recommend you boost. you will run into problems and it will cost money to fix them. and if you dont have the money for to fix it then your basically s**t out of a car
