I've got a 91 Si I plan on doing a B16 swap on. The old D16a6 started giving up compression on the freeway and ate 2 quarts before 1000 miles after it's last oil change. He's due. I'd like to build this motor before it gets put in. My goal is 9000 rpm redline with 200 whp with a 60-75 hp hit of nos using a 1st gen B16A for simplicity's sake (also have an SiR gauge cluster to install with it ). Looking for it to be relatively drivable, I don't want a radical idle or anything like that. Just lots of juice.
Assuming: complete block/head, ecu and all the "typical" stuff that comes with a complete swap, where is the money best spent to get this output and not fling the engine apart at 9000 rpm? Will the bottom end need beefing for this much power (con rods, pistons)? I have a short ram intake, and headers to catback that should fit. I'm thinking: cams (stage 1,2,3?) & adjustable gears, get the moving bits balanced, up the compression with some machining (how much?), new axles, new intake and throttle body (70mm?), new clutch (stage 1,2,3?) and flywheel (9.5, 12 lbs?), plus a bunch of the recommended stuff like timing belt etc. I'm looking to do a comprehensive NA upgrade. Am I overshooting it? Too much? Too little? What am I forgetting? Help me out!
Would need a custom tuned ecu also, almost forgot.
