Yeah , I believe i saw someones post here about replacing all the things you mentioned Mitcheg6, and i think i added you to my aim buddy list as I had quite a few questions for you.
but currently the engine is out and im welding/shaving all the un necessary holes and need to paint the b***h before i put the engine in it.
wiring questions -- Yes please
def going to spend a bit more time feeding in the transmission cables, some of the s**t ive seen looks so goddamn hokey and jacked up makes me puke!
I think everything in the interior will be a-ok with me upgrades and swaps, bought the jdm black suede/red stitching seats, although I would like to get my hands on the black interior pieces rather then trying to paint the grey s**t :/ unless someone has good paint that dosent make vynal look horrible.
As for probably going to get the hasport engine mounts and civic axel combo from hmo motors and the lsd should put my engine/lsd/axels should run about 3000.
other then that I think the only thing that will be interesting will be to hack up the orignal wiring harness for the h22 and adapt it to the one that came off my d15b8 but not really sure what they mean from HMO online as to "COMPLETE" wiring harness and ecu... guessing here "harness on the engine and ecu" but not the cable that connects the ecu to the engine..
and the other thing as doing completly tucked wiring running through the frame on the left and right side of the engine.
along with non visable brake lines and a custom porportning valve mounted inside the car most likely around where the gas/trunk release latch are located.
basicly my motto is, if you dont need it i dont want to see it, simplify everything looks wise along with electrical of the car, mostly the shaved look
