it has about 160K kilos and it is not driven hard at all, the misses drives it plus it is an automatic.That's generally carbon build up. That engine is filthy.. run something like Seafoam (many will debate this) or an engine cleaner on that thing. Oil burning will usually be noticeable in a distinct drop in oil level/pressure. Also, how many miles does this engine have? Do you drive it hard?
That seems low for that much buildup in there. Is it running lean/getting bad fuel mileage?it has about 160K kilos and it is not driven hard at all, the misses drives it plus it is an automatic.
well there is a check engine light for the evap, checked the live datastream for both O2 sensors and works fine. could it be the car is driven short trips everyday? about 30 minutes to work and then 30 minutes from work?That seems low for that much buildup in there. Is it running lean/getting bad fuel mileage?
