I'm currently working on a fully built N/A b18c1. My question is how high of a cr is safe to run a 75 shot? I'm planning on running 12:1-12.5: & e85 if that makes a difference. Is that cr too high?
compression makes no difference on the size of the shot you can use.I'm currently working on a fully built N/A b18c1. My question is how high of a cr is safe to run a 75 shot? I'm planning on running 12:1-12.5: & e85 if that makes a difference. Is that cr too high?
well, then it breaks from the nitrous... not the compression.Wouldn't say compression doesnt matter. There is a point where stuff breaks under to much nitrous. Good tune is best thing for it. Are you going direct port nitrous? Or fogger?
Direct port since i'm going to be running itbsWouldn't say compression doesnt matter. There is a point where stuff breaks under to much nitrous. Good tune is best thing for it. Are you going direct port nitrous? Or fogger?
what is your build going to consist of?Direct port since i'm going to be running itbs
