did the honda speakers work before you took them out? cause if they worked than that means the wires are fine. you probably didn't connect the new ends very well. I know you had to cut off the Honda plastic connectors, but when you rapped the new 6" piece of wire that comes with the speakers to the existing wire did you do a good job? also I'd wrap it in electric tape, if it touches metal like the door, or get's wet it can make it not work. double check the wires, wrap them in electrical tape, and make sure you have the big female piece on the big male piece and same goes for the little ones. if their on the wrong sides they also won't work.
