Dice316
So i took my 93 coupe to TiersPlus to get an alignment and they showed me my passenger side front wheel the CV axel boot is broken off (seperated) from the end (closest to the wheel) i can litteraly take my hand n move it back and forth, they told me i need a new CV Axel and if i replace one side i should also replace the other then take it back to get re-aligned - question1 yes i agree if i replace one side i should just replace the other but i noticed L and R are usualy sold separetly is that cuz its uncomon to replace them both at the same time? 2. as much as i want to do both if i just replace the L side is that ok to drive or will it make a big difference or mess other things up? 3. they said my tierods were fine and when i drive my car n stearing wheel is still very shaky (no powerstearing) do you think fixing the CV Axel will fix it and make it more sturdy so the wheel dosnt try to force it self out of my hand n swerve the car each time i hit a small dent in the road?
also i noticed on ebay when i look up the CV Axel i see some of them saying with out ABS ...do i need to buy the ones with ABS or can i buy ABS seperate, or use the old ones...or do i even need to worry about ABS at all?
if you need more info i have a :
93 Ex 2-door Coupe
99 D16y7
Tokico Blues lowered a bit
and 18" wheels
93 Ex 2-door Coupe
99 D16y7
and 18" wheels
