Originally posted by ikon_em2
if u have the rsx type-s then u will have an LSD
Nope. That motor does not have an LSD. In fact, there is no K-motor in the US that is equipped with a stock LSD. Same goes with any K motor in the UK as well as AUS.
On the K-motors there are only stock LSDs located in the DC5R, the EP3R, and quite possibly the Euro Accord R in Japan (since it uses the same engine as the DC5R, but it may or may not have an LSD).
The Euro EP3R is NOT equipped with an LSD (as it uses the same engine as the RSX-S with a slightly higher compression and same HP/torque #s, blah blah, etc.)
The Ausie Integra Type R doesn't even use the DC5R engine, it uses the same engine the Euro EP3R has with no LSD (while everything else is authentically Type R'd out.)
So all in all, the stock LSDs are located in JDM-land. Makes you wonder if Honda is trying to get JDM credibility to their USDM JDM fans... ha.
