as of right now i have a 91' hatchback Si with a b18a1 swap in it, and a 88' crx dx with the stock motor. What im doing is exchanging the two motors one to the other and vise versa. now with the crx getting the b18 all i need to to is take all the goodies out of the hatch ie:motor, tranny, mounts, shift linkage, cv axels, wheel hub assembly and brakes, along with the ecu. and than wire up mpfi.....does this sound right??? And to put the d15 into the Si hatch, all i need to do is take everything out like the i am for the b18.??? now with the mpfi wire harness in the Si will it work with the d15 dpfi? i think i would need to switch the green/white and yellow/white wires around on the TPS cause the d15 runs backwards. is that correct? ive just been thinking too hard about this and now i cant think straight. I know many people would just say wtf are you doing putting a d15 in a si body, and why go through all this trouble. well i like my rex a lot more than the hatch. and would rather boost a b18 in there. Any anwsers would be greatly helpful. i already have the b18 pulled just need to get my wheel hub assembly and brakes off. thanks in advance for any and all help!!!
i posted this on superhonda also but im hoping those of you who dont go there will see this and might be able to help me
