As the title says I have a DuraTrax Nitro Evader for sale. This is a Gas powered rc car.
The motor was sent to the factory because a recall and not one gas tank has been run through it.
This car also has a venom fail safe so you will not over heat and destroy your motor.
Also Rebuilt all servos and in perfect working order
Has a bigger gas tank for longer use without refulling every 10 min.
Willing to take $130 shipped or OBO My loss your gain
This is the 1/10 scale Glow Powered, Radio Controlled, Rear Wheel Drive
Duratrax Nitro Evader Off-Road Ready-to-Run Stadium Truck.
FEATURES: Chassis: 7076 T-6 blue anodized aluminum, 0.12" (3mm) thick
Drive: Rear wheel drive
Drive Type: Gear driven
Engine: 0.18 (3.0cc) two stroke Duratrax pull-start with two needle
rotary carb, heavy duty connecting rod, and dual ball bearings
Exhaust: Tuned pipe with header
Radio: Two channel AM pistol grip with trims, adjustable steering
rate, battery LED, charge jack for optional NiCd batteries, two
standard servos, and BEC receiver
Fuel Tank: 2.5oz (75cc), flip top cap
Clutch: Two-shoe
Transmission: Single-speed
Ball Bearings: Fully equipped, 16 total
Shocks: Four oil-filled, Rapid Tune aluminum body with coil-over
springs, adjustable spring tension
Gearbox: Sealed
Differentials: Adjustable, ball type
and conserve power
Brakes: Single disk, composite material
Front Tires: 2.2" (55mm) inner diameter, 2" (51mm) wide multi ribbed
XTR-M2 rubber compound
Rear Tires: 2.2 (55mm) inner diameter, 2" (51mm) wide M2 bowtie tread
Wheels: White 1-piece plastic, dish style 2.4" (61mm) outer diameter
2" (51mm) wide
Body: Highly detailed pre-painted and trimmed stadium truck with
decals, color scheme varies between radio channels
Suspension: Fully adjustable with multiple shock mounting positions
Camber Tie Rods: Adjustable
Steering Tie Rods: Adjustable
Steering: Bell-crank
Servo Saver: Included
Warranty Period: 90 days
Forgot to mention up top I have a hot shot 2 for it which is rechargable. comes with charger I will include this too. All you will need is nitro fuel and have to tune it
I am not a big fan of the body but It was never ran with the body on the car
Clutch: Two-shoe
Gearbox: Sealed
and conserve power
2" (51mm) wide
