EF Build
B2ohBOOSTED
theres alot more to make ur car turbo than what you have... hope ya know that...
plazmascivic
rockin those D's
x2 do some "beefing up" before u put the blower on, or else u could do some major damage
BADFISH
no disrespect but It's not a blower it's a turbo.
Yeah the motor is getting beefed up! however, you can run a turbo on stock connecting rods!
Steven.
Formally Green 91
:word:
but why woudl you, eagles can be had cheap. or tuner toys rods
BADFISH
:word:
I don't know why anyone would take that chance! I've been around cars for 11 years & never have I seen a connecting rod so small!
Steven.
Formally Green 91
hope there YCP vitaras
you shoudl use HONDA rings and not the vitara piston rings
BADFISH
Yup there YCP pistons!
More pics!
need to come up with three more bolt =)
Steven.
Formally Green 91
vitaras with a stock intake manifold and HF manifold?
dosent make sense to me.
vitaras are more used for high boost/high HP numbers. not low boost.
since the CR will be low, it will probably be a slug out of boost.
BADFISH
What don't make sense! turbo's trive in a small port environment, on the other side of the spectrum N/A trive with larger ports. Second I'm not running the hf manifold because I want to. The turbo I have is a mits twin scroll. aka instead of the rectangle for the exhaust intake, there are two triangle shaped ports. So, it's was either a custom exhaust manifold with a evo flange or modify the hf.
With turboedit I'll be running 10psi! I don't care what anyone say's no cast piston is safe pass 15psi Reliably.
CR willn't be low it will actually be .01:1 higher than a stock D16Z6!
Steven.
Formally Green 91
with vitaras?
in a z6 there abotu 8.8:1
im mean there damn good pistons for being cast and not forged.
people make 400+hp with them on stock sleeves
BADFISH
with vitaras?
all the calculations I have say 9.14:1 with Z6 head & block 75.50mm bore & 2-layer Y8 Head Gasket. complete stock d16z6 comes in at 9.13:1 on http://www.cspeedracing.com/howto/compcalc/compcalc.php. I may be getting someting wrong but that's what I come up with. The only thing that could be wrong is the compression height, it is 30mm on the vitara's right.
Don't get me wrong they are good pistons! but, to play it safe I would never put over 15psi on them!
Steven.
Formally Green 91
id reccomend a upgraded head gasket.
ill be pushing 300whp on my DOHC ZC, not sure what psi it will be at im guessing aroudn 15-20
BADFISH
I am, I found a place online that makes custom copper gaskets for around $90.00
really, sounds like a fun project. If I had the money i'd be doing something like that! this is my cheap turbo setup until I get out of school! Are you sleeveing the block with that hp goal?
Jason-
jdm king :p
Looks like an excellent build, so far.
Best of luck and I will be spying(on here. =) )
-Jason
Steven.
Formally Green 91
you can get a cometec. i woudlent use a coper HG on a honda block, i havet heard good things about them.
nope stock sleeves.
stock D series sleeves can hold 400+hp when tuned and done right.
ill be running around 8.5:1 CR
Steven.
Formally Green 91
really? no f**kin way i never knew that, haha it was a figure of speech god all u guys need to get a sense of HUMOR JESUS f**king CHRIST!
what the f**k is with your attitude lately?
knock the s**t off.
plazmascivic
rockin those D's
wow stock sleeves can really hold 400hp? dude i never knew that, thats cool,
