6thGeneration
What are the negative effects that occur to your car when you drift using the hand brake and what-not?
when drifting you are putting extreme amounts of force on your upper and lower control arms, ball joints, and even more on your strut/strut tower mounts, that's just to start, your steering rack while in a slide or "drift" will be put on the braking edge trying to keep your steering knuckle and wheel turned into the direction of your slide, while all this transfer of force, thrust and friction is happening your uni-body sub frame shell is twisting in opposite directions from front to rear. so long story made longer followed by a short, sweet and to the point answer... yes effects your factory or semi custom car greatly in a neg way.So it doesnt doing anything to the alignment or the structural integrity?
Depends man. if you're drifting on nicely paved surface i can't see why it would thro the alignment off. You can actually have the car aligned with intention to drift. In this case, the car would not be aligned as a ordinary car. Structural? depends too man, specially on the age of the car.So it doesnt doing anything to the alignment or the structural integrity?
You're waaaay over thinking this... Doing 20mph power slides in a parking lot every once in a while will not stress the car very much and won't do any severe damage. You're more likely to severly wear or damage components driving through a city with crappy roads. Believe me, I've been beating the crap out of my car racing for the past ~7 years. Still have stock, ~218k mile/17yr old upper control arms, original ball joints, original steering rack, blah blah. All perfectly fine. The body and subframes of the car will not be damaged... And surely your shocks/mounts will be fine. After all it's their JOB to absorb bumps and control movement.when drifting you are putting extreme amounts of force on your upper and lower control arms, ball joints, and even more on your strut/strut tower mounts, that's just to start, your steering rack while in a slide or "drift" will be put on the braking edge trying to keep your steering knuckle and wheel turned into the direction of your slide, while all this transfer of force, thrust and friction is happening your uni-body sub frame shell is twisting in opposite directions from front to rear. so long story made longer followed by a short, sweet and to the point answer... yes effects your factory or semi custom car greatly in a neg way.
Ummm... Did you not read that my stock controls arms are stock, ya know, original bushings and all? Yeah, bushings are fine. And that my ball joints are original... And fine... And all my other stock components, and unibody, and other junk you mentioned would be wearing. Guess I'm that .1% lol...OK there bro, that's why your running an almost fully upgraded suspension kit, and no sh*t the steel arm its self will hold up when referring to control arms its the bushings that 99.9% of the time go bad, just figured we on the forums had enough common sense to put one and two together, apparently not.
And to toss some more gas on that post of yours going up in flames, big difference in extorted force's when "rally racing" "street Racing" and that of true drift, hell you even said it your self
o...m...g... "Vertical motion not a horizontal".. WHAT? Wait, using your logic, that means the suspension on every car out there cannot handle the forces exerted laterally. BUT WAIT! Every car out there can turn! Taking on lateral forces! Wow... common dude. This shows me you don't even understand the very basics of suspension geometry."And surely your shocks/mounts will be fine. After all it's their JOB to absorb bumps and control movement" ya for a vertical motion not a horizontal, and to clear up one last thing the slower the drift the less of the lift, the more of a tire surface contact which means.... more drag a friction, or you know us drifters just like to up grade our factory suspensions for the hell of it.
Did I not say you were right that the car IS under stress(it's obviously not just static)? But, that it is under no more stress than driving around on terrible roads? The bushings are stressed, but they will not tear/shread doing a couple little power slides...My bad is this not your writing, and if you read instead of thinking you know drift just because you "rally" or race street tracks, then you should have understood its not the steel arm that goes bad (unless bent) but that's rare, its the bushings.
what ever though if you want to get your info from him well sorry in advanced i ran a 240sx se in line 2.4L 2 step for a good while, i know my sh*t, so hit me up if in need.
