Ground Control Coilover Kit
With so many companies offering coil over kits, it can be confusing choosing the right one for you. Let Ground Control clear up the confusion.
•First, Ground Control has been building suspension kits for over 18 years. With that much experience in engineering suspension systems, you and your vehicle benefit. We dont make universal kits; our parts are designed and machined to fit each individual application – thats over 200 different kits!
•Second, Ground Control suspension kits use only the highest quality components. Coil over hardware is made of ultra high strength aircraft aluminum. Our unique single nut adjuster allows easy one hand adjustments. Urethane adapting hardware both insulates and secures coil over hardware to the shock absorber.
•Ground Control uses only the highest quality springs on the market with our coil over hardware. Eibach springs are unsurpassed in quality, engineered for maximum travel and guaranteed for life. Ground Control stocks over 175 different Eibach Springs to create the custom ride you expect.
Starting at $314 Shipped
http://www.tunersports.com/products/ground-control/ground-control-coilover-kit_340.html
