i would like to know, how work a FMU...
i have seen a guys that boosted her cars and did put it...
stealthy said:FMU's
An fmu increases fuel pressure at the injectors. If you have a stock fuel pump, its not gonna be able to keep up with the fmu. But if you do have an aftermarket fuel pump, and still have stock injectors, the FMU will create the pressure to the injectors but the injectors arent gonna be able to spray out enough to keep up with the fuel pump. Fuel produces optimal power when atomized, it ignites much better than raw fuel will, and the higher the fuel pressure is the less atomization occurs.
As someone once said on HMT, think of it like a can of hairspray, if you take the can of hairspray and hold a lighter in front of it and push the nozzle, an atomized mist of hairspray shoots out and makes a big fireball.If you take that same can of hair spray, spray it on the ground in a puddle, it'll burn...but not nearly like the first time.
Fmu's are out dated devices used by muscle car guys with carbs bc they didnt write a new program for their ecu. The FMU will cause you to run pig rich, and they are no where near being efficient. These are old options nowadays, and who wants toasted injectors and leaned out spark plugs? They are brain dead pieces. Fmu's are by far "old school" considering your ecu chipping options that are available now, not to mention chipping your ecu is not only more effective, usefull and cheaper in the long run.
Boosting? Do it right the first time, dont skimp. it will cost you major $$$ in the end
